Linde H25T 392 (DOM:2004) Hydraulic Problem
Hi, I have a H25T with failing hydraulics. I have just carried out the following:
1.) Side-shift hydraulic cylinder - new seals (works fine)
2.) Joystick (1 of 2) right-hand side... side-shift control (works fine)
Lifts and tilts, but doesn't hold. The tilt is the worst as all hydraulic pressure dissipates almost immediately. Hydraulic oil level seems to be good and stable and there doesn't seem to be any sign of leaking oil.
The tilt pressure was failing prior to the above-mentioned repairs, and presumed to be related to the leaking side-shift cylinder (which was severe).
Could the problem be related to the new (after-market) joystick, or do I need to bleed the hydraulic system? Any advice would be much appreciated.
  • Posted 28 Sep 2025 19:59
  • By Robert_Douglas
  • joined 13 Sep'25 - 4 messages
  • Qld, Australia
Check truck for a accumulator cylinder if it has one that can allow controls to work without truck on but if not could be other tilt passing internally
  • Posted 14 Nov 2025 06:51
  • By mobbsy
  • joined 30 Apr'13 - 25 messages
  • Cleveland, United Kingdom
thanks imobbs
Hi Andreas,
Thank you very much for the advice. I shall test as advised. I'm guessing that if it's the joystick, there will only be a pressure issue when running?
Also I hope I made it clear that it was the side-shift joystick that I replaced?
Thanks again,
Robert
  • Posted 7 Oct 2025 21:38
  • By Robert_Douglas
  • Qld, Australia
Hello Robert,
first, side shift has nothing to do with the other hydraulic functions. I think you have a joystick issue. New joysticks need to be calibrated otherwise evil wizards will take over control. You can check, if the lift and tilt stops moving when you switch off ignition, you have to do a calibration of the joystick. For the calibration the Linde Software and dedicated interface is required.
  • Posted 7 Oct 2025 05:15
  • By andreas_k
  • joined 22 Nov'09 - 6 messages
  • NRW, Germany
Taylor TXB180S
Rail King RK330
Powerfleet
AI-enabled safety and compliance solutions for material handling operations.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
