no drive in forward and reverse after first start up.sometime i can feel it trying to move but not.and does not rev at first as well.
found brake valve block leaking replaced still the same.
but if you push down on the rev pedal very slowly it will move but it wont do it in forward.
when it move in rev then the truck will drive around ok.when truck is turn off then go back to it wont drive unless you press down on the rev pedal very slowly.
I too have had a similar problem, I replaced the engine speed sensor mounted between the engine and the hydraulic pump for traction.
I did not have any kind of alarm.
Regards, Mirko.
Have you tried replacing engine speed sensor, that can cause the issues you describe. Doesnt always bring up a fault code either
FIRST QUESTION YES
SECOND QUESTION QUICKLY
THREE QUESTION MAST OPERATE NORMALLY
Hello, the diesel engine accelerates if you press forward or backward?
When you release the pedal direction, the motor will decelerate slowly or quickly?
The hydraulic mast operate normally, or you have problems in this case?
you dond hef code s on display??????????????
H25D MODEL
H2X39R00537 SERIAL
