Linde H25D 392
My subject forklift runs for 30-45 mins and motor overheats.
Surprise to see Fan motor stops. Switch off and On the fan motor runs once again for 30-45 mins.
Changed Hydraulic oil VGA100, all Hydraulic filters, Fan motor assly, Steering pump assly still problem persists.
The Fan motor solenoid is bypassed.
Kindly suggest.
  • Posted 30 May 2015 19:48
  • Discussion started by naveen_s
  • karantaka, India
hi , check the fan cardridge in the hydraulic block. In diagnose Pathfinder you see 1600-1400 M amp. the pressure of the spring in cardridge importend.
  • Posted 8 Jun 2015 15:34
  • Reply by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi, thanks for your suggestion, checked the same, replaced the thermostat, changed the coolant (G12).
Problem still persists Engine overheats after the fan stops.
Reset the key and the fan works for another 30-35 mins.
Please suggest.
  • Posted 7 Jun 2015 14:30
  • Reply by naveen_s
  • karantaka, India
HI , if your engine overheat you must first check the cooland and thermostaat.
  • Posted 4 Jun 2015 01:00
  • Reply by gc_d
Regards gc_d
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
edition #1229 - 8 May 2025
