Linde H25 Release Drive
We need to tow a Linde H25, is there a release for the drive to allow it to be towed?
  • Posted 11 Mar 2011 18:26
  • By nigel_p
  • joined 8 Jul'10 - 20 messages
  • Worcestershire, United Kingdom
nigel@pandhlifttrucks.co.uk
Some others may have diagnostic tool but it would be unlikely because the pressure test kit is expensive and you need to know what to test. Best advice has been given by duo as other may screw your truck even more by not knowing what they are doing. You have high pressure to drive the wheel motor but also low pressure to control valves. Pressure test kit is needed on hydrostatic truck.
  • Posted 17 May 2012 09:32
  • By Dwaive
  • joined 7 Aug'09 - 33 messages
  • Quebec, Canada
The operators manual will not help you troubleshoot thus truck and the service manual won't either unless you have a Linde hydrostatic test kit.
If it were me I would not drive the truck anymore and call your local Linde dealer fast. They are the only ones whi have the tools and expertise to fix this truck.
  • Posted 16 May 2012 04:31
  • By duodeluxe
  • United States
duodeluxe
Hello there! Could I still have the operator's manual for a Linde H20D 351? I guess it must be pretty much the same as the H25D. I am in desperate need of some advice on how to sort out the lack of power in the drive....the truck moves but not very fast and it feels as if the brakes are half on. Many thanks!
  • Posted 16 May 2012 04:13
  • By kipool
  • joined 1 Oct'10 - 11 messages
  • London, United Kingdom
kipool1@aol.com
If you don't hve the operator manual, let me know and I will provide it to you
  • Posted 16 Mar 2011 09:26
  • By Dwaive
  • Quebec, Canada
You must release the brakes as it was said previously, but additionally you must bridge the hydrostatic transmission. Without this the transmission will act as a brake.
There's a valve near the servo block. Releasing it you may release the hydrostatic brakes. It is shown in the operating manual. Look there.
  • Posted 16 Mar 2011 03:04
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
on controler turn grease nippel in till locked gif 2 good pumps of grease then locate tow valve on side of drive housing loosen lock nut usually 18/19 mm spanner tern pin with 10mm spanner out 2 full turns
  • Posted 15 Mar 2011 19:00
  • By Egmont
  • joined 15 Mar'11 - 6 messages
  • Gauteng, South Africa
If someone made it i can fix it
Burn it
  • Posted 14 Mar 2011 02:54
  • By Snapman
  • joined 10 Sep'08 - 53 messages
  • Liecester, United Kingdom
look at the brake valve and you will find a grease nipple. Insert grease with your grease gun manually until the brakes are released. Do not use too much pressure as you will damage the system. You will find the complete procedure in the operator manual that must be with the truck, probably in the pouch behind the seat
  • Posted 13 Mar 2011 15:21
  • By Dwaive
  • Quebec, Canada
hi
for tow you need to unlock the brakes whit grease its no easy for one thas dont now the equipment
  • Posted 12 Mar 2011 07:39
  • By manuel_e
  • joined 26 Feb'11 - 3 messages
  • amadora, Portugal
Serial No starts 351, sorry that is all I know, has I haven't see it yet!
  • Posted 11 Mar 2011 23:32
  • By nigel_p
What is the serial ?
  • Posted 11 Mar 2011 22:44
  • By duodeluxe
  • United States
duodeluxe
Muncie, IN, United States
JLG G12-55A
Toyota 02-8FD30
JLG G12-55A
Toyota 02-8FD30
