Linde H20D H2X392T003336 hydraulic problem
Hello everybody. The above truck truck has a triplex hi-lo mast with five cylinders. When i actuate the lift lever at full speed the second part of the mast rises at the same time with the fork cariage. Any idea what maybe wrong?
Thank you.
  • Posted 19 Nov 2012 23:59
  • By Touristas
  • joined 14 Jan'12 - 30 messages
  • GREECE, Greece
Thank you all for your usefull information. I will check it.
Best regards.
  • Posted 26 Nov 2012 22:42
  • By Touristas
  • GREECE, Greece
tight rollers might be the cause but this is usually accompanied by scraping or some other abnormal noise while the carriage is traveling up and down. michel's suggestion is more common as i've see quite a few valve issues lately. A faulty safety valve can cause this exact symptom.
One trick to see about this is to raise the mast all the way up, then lower it, and see if it does it anymore. If the problem goes away then it is most likely the safety valve. If it does not then i'd look elsewhere. Still you will probably be breaking the cylinders down to see what the problem is.
  • Posted 26 Nov 2012 15:19
it can also be a safety valve in the celinders
  • Posted 25 Nov 2012 16:08
  • By michel_v
  • noord holland, Netherlands
Could also be caused bij bad rollers (bearings) on the forkboard.
  • Posted 24 Nov 2012 20:56
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
Thank you very much my friend. I will change the seal kits.
Best regards
  • Posted 21 Nov 2012 23:08
  • By Touristas
  • GREECE, Greece
This could happen when the hydraulic fluid is cold and with no load on the forks. That is normal.
If it happens all of the time and with a load then it would indicate that you need to reseal the smaller 4 cylinders. You should do all 4 at the same time since the kits are way lees expensive than the labor to get to them.
  • Posted 20 Nov 2012 23:47
  • By duodeluxe
  • United States
duodeluxe
Muncie, IN, United States
RAEDER-VOGEL
