linde E16 no drive contacts energising.
Model:E16P,Ser No:322A04500316
This is an older twin drive model which is not bringing in any drive contacts.
Lift and steer working. I believe I have lost main supply to contacts but not having any wiring info makes it hard to trace back. I have tried another pcb.
This truck has no seat switch or handbrake switches.
The direction switch on footpedal is working and pot is varying voltage.
If I can get hold of a wiring schematic I should be able to get to the bottom of this.
Hopefully someone can supply this diagram or shed some light on the issue.
Thanks
  • Posted 8 Sep 2016 03:09
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hi I have the same problem with my old E16 Lansing forklift, can you share info which might help me find the fault, do you have a wiring diagram, also do you know where to find the chassis number on these old machine's, cant find a plate anywhere and thought it would also be stamped somewhere, many thanks
  • Posted 29 Sep 2021 21:35
  • By Morton_Hannah
  • joined 29 Sep'21 - 6 messages
  • United Kingdom
Hi
Model:E16P,Ser No:322803501516 Year 1988
I have a traction problem. Lift and steer working.
I need manual-wiring diagram
eriflona(at)yahoo(dot) com
Thanks for help
  • Posted 15 Feb 2017 06:22
  • By gianni_d
  • joined 8 Jan'17 - 3 messages
  • BT, Italy
Sorry if some questions will be trivial, but I'm new in this job.
Thanks Once again to everyone that provided me with wiring info. It was the wiring from the fuse supply to the footpedal.
The switches were fine but the supply was missing.
Thank You
  • Posted 9 Sep 2016 02:54
  • By elektrodrive
info on the way!
  • Posted 8 Sep 2016 19:15
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
Crown SX3030TT4250
Toyota 8FD45
