linde e14
hy,
i have a costumer with a linde e14 with sn: A2X3BN05787 (48V, year 2002), if i turn the direction full to one side, the forklift stops and need to be switch off/on. i meassure the voltage and varies between 2-12 with 14,6v supply. i notice that the side it fails the oposite traction motor inverts earlier then the other side. Does it mean that i need to calibrate the poti?
i also can get borrow a calibrator but it only show numbers, he didn t have the list with the parameters :-(
thanks in advance for any help
david
  • Posted 11 Mar 2010 10:05
  • By dacarr
  • joined 25 Sep'08 - 11 messages
  • Leiria, Portugal
I am looking for a service manual E14-02 edge and R12C, give service to a customer but I have no information of these forklifts; thanks for any help
  • Posted 27 May 2012 00:30
  • By alonso_reyes
  • joined 5 Jul'11 - 48 messages
  • kyku, France
montacargasmsi@gmail.com
hello. what about the acelerator potenciometer, take it in your hands an check the spring tension verticality of the pin
  • Posted 26 Apr 2010 03:53
  • By sergio_v
  • joined 14 Jan'10 - 2 messages
  • great region accra, Ghana
la practica hace al maestro
hef one look for fuses
  • Posted 21 Mar 2010 05:38
  • By michel_v
  • noord holland, Netherlands
Error No. 39 & 45 said that one of your intermediate circuit was not charged enough voltage to switch ON the controller. Try to check the followings possibilities : Battery voltage, Charging circuit including charging contactor K2/K3 and charging resitor, check all the electrical contact on this path e.g. wiring connection and keyswitch,....or your power module have short circuit inside to make a bybass the capacitor and ever get the expected voltage >70% battery voltage ?
Good luck
Rgds
  • Posted 21 Mar 2010 00:02
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
sent my one mail my frend
  • Posted 19 Mar 2010 03:45
  • By michel_v
finaly got time today to test the new potentiometer at the rear wheel, but after change and adjust (7,5v at the middle), the forklift doesn t run anyway, and the line contactor don t close.
i ve checked seat and cabin microswithch, seems ok, tried with the programmer at window 2 it shows me 45 and 39. on the window 81 the data from wheel angle seems to be ok.
it is an linde e14-02 sn:h2x335n5787 from 2002, and it has software v 1.7 1.1, i think
thanks for answers
  • Posted 18 Mar 2010 06:51
  • By dacarr
  • Leiria, Portugal
Look at window 8 or 81 at your callibrator
Cheers
  • Posted 12 Mar 2010 07:44
  • By blackie
  • joined 9 Jul'06 - 52 messages
  • Gelderland, Netherlands
David good, look at the rear wheel potentiometer.
  • Posted 11 Mar 2010 23:36
  • By fernando_r
  • joined 5 Mar'10 - 33 messages
  • Spain
Deborah Baker Deborah Baker
Muncie, IN, United States
