LINDE E 20 336
Good day,
I have troubles with my Linde E20-02 336.
My machine displays error code 92.
Lift works, just no traction.
All switches are functional (parkbrake, cabin switch, seatswitch)
Potentiometer is functional and calibrated
According to TruckExpert the code means:
The fed back voltage of power unit 1A1 does not match the preset PWM clock pulse ratio.
Anybody a idea?
Or should I just bin the LDC?
Kind regards
John Kivits
  • Posted 8 Oct 2019 01:35
  • Discussion started by Johnkivits
  • Gelderland, Netherlands
Hello there. I have this problem too. How do we solve it, did you solve it?
  • Posted 22 Feb 2021 19:24
  • Reply by Tarik_Acar
  • Turkey
connector X13 pin 34 was loose same machine same problem
  • Posted 23 Oct 2019 04:02
  • Reply by Alberta
  • Alberta, Canada
truckshop@lonepinecolony.com
i've only in deutsch language:
Fehler im Pfad X13:30 - X11:21
oder
Fehler im Pfad X13:10 - X11:22
oder
Fehler im Pfad X13:31 - X11:13
oder
Fehler im Pfad X13:24 - X11:23
oder
Fehler im Pfad X13:43 - X11:4
oder Defekt im Leistungsteil
  • Posted 17 Oct 2019 07:47
  • Reply by Lukasz
  • Poland
Greetings
Lukasz
hoi , controleer rijmotoren op lekspanning , kan je zien of er een fed open blijft staan in diagnose?
menu:
Venster 61 Ut: 1,3V Venster 62 Ut: 1,3V
Ub: 1,3V Ub:1,3V
Moet 0! volt zijn
  • Posted 9 Oct 2019 01:57
  • Reply by gc_d
  • Zuid-Holland, Netherlands
SMV (Konecranes) 4531CC5
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
Hangcha CBD15
China
USD1,600
Toyota 8FGU25
edition #1235 - 19 June 2025
