Linde code's 221 280
julio_r
Texas, United States Hello, Everyone My name is Julio and we have 2 Linde's here in our plant, and we been running into problems the linde H50D is giving us some code "221" and "280" and just wondering if anybody can help me out here, once the code go off the linde wont lift anything and it runs in low speed like were forcing it, can someone please help me out I'm kind off new to linde's, I would be thankfull...
  • Posted 18 Aug 2009 02:08
  • By julio_r
  • joined 5 Dec'08 - 5 messages
T 483 safety processorpomp control in forward direction notplausible in relation to accelerator potentiometer
T 248 speed sensing fault
D 156 traction heartbeat masage mising for over 400ms
  • Posted 15 May 2014 02:01
  • Modified 15 May 2014 02:13 by poster
  • By michel_v
  • noord holland, Netherlands
T 221 production test not ok
L 280 safety relay Always off
  • Posted 15 May 2014 01:49
  • By michel_v
Hello guys,
I have a linde truck model H30T,I have a fault D156.
Can somebody tell me how I can fix this fault?
Thanks in advance.
  • Posted 14 May 2014 17:28
  • By Paulorossi
  • joined 14 May'14 - 2 messages
  • romania, Romania
Hi Herald I appreciate your help, this morning as we started the Linde it looks like the codes were gone but as I start to drive it around the forge shop I notice two different codes "T483" "T248" and now and very confused it looks like were going to have to get a Linde guy over to hook up the computer but this days there so expensive per hour......Thanks for you help Herald
  • Posted 19 Aug 2009 02:13
  • By julio_r
Hi julio
The fault code 221 should have a T (traction) or L(hydraulics)before the code if it has a T then you have a voltage problem inside the controller.This fault will cut drive to creep speed.
The second code 280 is a hydraulic code and again is a low volage fault inside the controller.This fault will disable the hydraulics.
It looks like you will need to replace the control module in the cover behind the seat.
cheers
herald.
  • Posted 18 Aug 2009 07:47
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Unicarriers FHGE35T5S
Aichi SR18A
