Linde 394 VW P-D diagnosis
Hi, I've got problems connecting my Pathfinder software (3.6.1) to Linde 394-02 with VW P-D engine; can't connect to the engine software,
I'm using a 3903602503 cable, and a generic RS232 to USB adapter.
Do I perhaps need a Linde original adapter? I've been going through parts lists and found 3903605115. Is that it? I see it's supposed to be for the old Canbox...
  • Posted 11 Jan 2018 05:33
  • Modified 11 Jan 2018 05:34 by poster
  • Discussion started by jure_t
  • none, Slovenia
hef you good drivers and comport??????????????
  • Posted 31 May 2021 02:01
  • Reply by michel_v
  • noord holland, Netherlands
I can't connect to VW cpy on any Linde. I can connect to the chassis. I have the latest Linde canbox. I use another device and software to connect to the engine to get faults and perform regenerations. Any thoughts or hacks?
  • Posted 28 May 2021 12:50
  • Reply by ricky_j
Rick.rapidlift@gmail.com
How did you get on with the pd servicebase
  • Posted 18 Jan 2018 20:54
  • Reply by Lindetech
  • Auckalnd, New Zealand
Has to be on com port 1
Them go into advanced and change the speed to 4 I think it's normally 16 as standard.
Then change the other one to 200 I think it's normally around 1200
  • Posted 13 Jan 2018 22:18
And what's the correct COM port setting?
  • Posted 12 Jan 2018 07:19
  • Reply by jure_t
  • none, Slovenia
Usb to serial adaptor will need setting up correctly
Linde recommend using there one but I use a keyspan one as long as the speed is set correctly
  • Posted 11 Jan 2018 22:14
Yeah,I figured as much.
Do you have any reccomendations for serial to USB converter?
  • Posted 11 Jan 2018 18:32
  • Reply by jure_t
  • none, Slovenia
not all usb to comport cabless work oke whit linde software
best is old laptop whit comport
  • Posted 11 Jan 2018 06:43
  • Reply by michel_v
