Linde 115-DC-2004 -Error code 48.1 (traction error code)
Hi friend,
I have a serious problem with the old truck 115-DC-2004 : Switch ON the truck has no error code - K1 ON. As soon as press the Acc. to drive the truck in some second it stops to alarm 48.1 - main contactor K1 =OFF.
- Change the new main contactor.
- Change the new charging contactor K2 and K3
- Check all the path metnioned in the manaual book for error code 48 traction LDC error code but all seem to be normal
Anybody has met this problem before, please help
Thanks in advance
  • Posted 2 Jun 2014 23:44
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
check for damage connection in wiring contactor to controlmodule. if everything oke you must replace powermodule drive/pump.
i have last time a truck with bad coil connection of contactor , it give same problem as you say.....
  • Posted 3 Jun 2014 22:40
  • Modified 3 Jun 2014 22:41 by poster
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi gc_d
Yes, I have checked it is enough just reduce from 50 to 48 VDC
I also change the new battery socket male and female.
Please advise more if you have helpful idea. Thanks you
  • Posted 3 Jun 2014 00:53
  • By Nuna
  • BK, Thailand
Thanks & Regards
Nuna
do you have check battery voltage same time with drive or risen the forks?
  • Posted 3 Jun 2014 00:34
  • By gc_d
Regards gc_d
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Bolzoni SpA (Group HQ)
Tacoma, WA, United States
Highland, IL, United States
Orlando area, United States
