limited traction and lift problems
I have checked out an EASI reach truck for limited traction speed and found that the truck needs a new forward/reverse potentiometer. I also noticed that the read out beeps and flashes "lift?" when keyed up. I have lost lift all together and have a code 21 show up once in a while. I tried to install a replacement pot today but the pot is also faulty. If I try to activate lift when the display shows "lift?" then the lift motor flashes up momentarily, stops and won't lift
  • Posted 10 Nov 2009 13:25
  • By islandtech
  • joined 10 Nov'09 - 5 messages
  • British Columbia, Canada
You enter the menu with the superword, go to learn feature, and learn controls
  • Posted 3 Mar 2010 09:39
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Could someone tell me the procedure after replacing the control handle to relearn it please?
  • Posted 3 Mar 2010 02:37
Hello Islandtech, where are you located? I've just moved over to the island and can fix that for you as well as find the superword for you.... email me infoatmartinsforkliftdotcom
  • Posted 22 Dec 2009 02:43
  • By martin_w
  • joined 27 Jul'05 - 13 messages
The handle needs to be relearned
You will need the superword for this
  • Posted 25 Nov 2009 01:27
  • By JonG
  • United States
