Lift will not go up...
Please help. My order picker will not go up. We change out both over mast cables, carriage card, coil card and check all connections. Before that it went up but, was slow after second stage. Also say initialize full speed on display... Any help will be greatly appreciated.
  • Posted 26 Sep 2017 17:13
  • By chee_v
  • joined 26 Sep'17 - 1 message
Is the lift motor turning on? If so could be bad pressure relief valve or hydraulic pump.
  • Posted 24 May 2018 20:15
  • By stam
Hi, did you check the mast switch ? Maybe a bad one, or bad connection
They are locate in the middle of the mast
  • Posted 24 May 2018 11:20
  • By Meden64
  • joined 13 Jun'17 - 11 messages
  • Quebec, Canada
Toyota 02-8FD30
SMV (Konecranes) 20-1200B
Toyota 02-8FD30
VETTER Forks, Inc.
