lift when pedal depressed
Serial B801N02249X
Hydraulic motor starts and platform raises as soon as deadman switch is depressed.
Hydraulic contactor working fine, all else on truck is fine.
Disconnected hand lever controls to eliminate switches - still lifts.
No wiring diagram to test control wires to controller (or wherever they go)
  • Posted 19 Sep 2017 08:37
  • By newbie705
  • joined 19 Sep'17 - 10 messages
You need to add your E-mail address to your profile. The file is too large to send in the response. I will send you what you need.
  • Posted 21 Sep 2017 06:46
  • By BREWSKI
agreed, however, without a wiring diagram I have no idea where the wires go, which plug they are connected to, or which pin in the plug.
even if someone can tell me which plug, I can test the 6-8 wires. Otherwise need to check all 6 control cables...
  • Posted 21 Sep 2017 02:39
  • By newbie705
If you disconnected the lift switch and the contact still closes you have a short in the wire harness. You will need to check the wiring from the control handle to the pump contactor.
  • Posted 19 Sep 2017 22:48
  • By BREWSKI
Michel Denis Michel Denis
Noblelift
