Linde (& Baker) E12:
Lift Stuttering, Air in Hydraulicsystem
Hello,
i have a problem with a Linde E12 386. It seems that the Hydraulic pump is getting Air from somewhere. It makes Noise and the Liftfunction is stuttering. I changed the Tank and the Pump already, but that didnt solve the problem.The Suctionhose is not damaged and i have no external leaks. Anyone have an idea?
thanks
F. K.
  • Posted 11 May 2022 21:16
  • Discussion started by F_Kleber
  • Germany
if the filter is becoming restricted so soon after a filter change i suspect the oil might be contaminated, i would have the oil tested and change it out to new oil with a new filter.
  • Posted 27 Aug 2022 23:24
  • Reply by swoop223
i had same problem
  • Posted 27 Aug 2022 18:06
  • Reply by michel_v
  • noord holland, Netherlands
Hello,
i took the Filter out and than it worked without problems. I will replace the Filter next week. The strange thing is that the Filter was already new. We just changed it a few weeks ago...
  • Posted 13 May 2022 06:01
  • Reply by F_Kleber
  • Germany
try to take filter out tenk
  • Posted 11 May 2022 22:39
  • Reply by michel_v
