Lift speed slow while traveling
Model 1N1L15V.
When lifting a heavy pallet and traveling, going into 2nd stage the pump slows drastically. Basically anytime you press the accelerator in 2nd staging it slows. If you stop lifting, take your foot off the accelerator, the pump speeds right back up. I have tried to change the settings in the dashboard but got nowhere. Any ideas/thoughts on this?
  • Posted 6 Feb 2015 07:20
  • By Loomyceejay
  • joined 6 Feb'15 - 2 messages
  • Michigan, United States
what Swoop asks about is my 'most likely cause' too, (best w.a.g., without a complete model and serial number, among other things)
but,,,
you should know that the manufacturer and OSHA all say the operators must be trained and know -not- to lift or lower while travelling, as it changes the center of gravity (more so with "a heavy pallet") in a manner that is 'less than as safe as possible", so actually watching the battery voltage AND travelling and lifting would not be the recommended manner to check the diagnosis, nor to operate the truck. I would suggest that you can stall the lift at full up for less than 3 seconds, and watch the battery voltage and get a much better idea and be 'more safe'. you will first want to read what the "at rest" voltage is, then compare it to the 'after 3 seconds hydraulic stall' voltage.
  • Posted 6 Feb 2015 22:45
  • Modified 6 Feb 2015 22:49 by poster
whats happening with battery voltage when this occurs?
sounds like the battery is dropping too low under power and is taking away power from hydraulics to run traction.
  • Posted 6 Feb 2015 16:28
Taylor T520M
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Taylor T520M
USD1
