Komatsu Reach Error E-10
I have a problem with an old Komatsu reach truck throwing up a fault code E-10. Unfortunately there is no plate on the truck with serial model etc, the customer thinks its an FB15 or FBM 15 something like that.
The system on it seems like the one they use on Nisaan electric trucks. A large gold cased card that sits on top of the IGBT's. There is no drive just lift works.
Any body have any fault codes that might tally with E-10 off a komatsu or even a Nissan perhaps, just to give me some idea:)
  • Posted 22 Apr 2010 01:30
  • Discussion started by elektrodrive
Komatsu FB15-12
Err14-8120
Err18-8120
Err30-8120
Err40-8120
?p??e?te ?a ß????sete?
  • Posted 17 May 2022 23:12
  • Reply by Giannis14
  • Greece
Hi saeidm , I have the same errors , have you found a solution?
  • Posted 24 Sep 2017 07:16
  • Modified 24 Sep 2017 07:17 by poster
  • Reply by tasos_t
  • ATTICA, Greece
Hy I have komatsu electric forklift we face some error codes can you mail me error codes list. Thanks
  • Posted 22 Aug 2017 20:46
  • Reply by noman_a
  • jeddha, Pakistan
komatsu FB15-12
error 40-8120
error 40-8140
error 40-8510
This device displays these error messages for no reason
please help
  • Posted 16 Jul 2017 17:03
  • Reply by saeid_m
  • ghadim, Iran
Hello, we are having Komatsu make reach truck, but since this is too old i am not able to find teh model & serial number of the same. Now I am facing E10 error on this machine. Except drive all functions are working. Can some one help me to solve the problem
  • Posted 11 Nov 2014 23:30
  • Reply by Amyjkm
  • Dubai, United Arab Emirates
hello
I need help for KOMATSU FB25H-1E year:1995???
there is always:F41 on dash display???
I check all wiring and power component (SCR&capacitor)
it means leakage of negative battery to frame!
really when i remove power steering and pump cable,the leakage decrease to 12V (between positif batery and frame) but even this solution the dash display fault F41(unsafe case).in the past i repaired this forklift and the truck move even with this fault F41,now,the fail safe circuit open direction contactors with arkin.
I don't found F33 fault that appear in the display?
I Change all necessary thristors (main SCR1,SCR2,SCR3)but i don't change commutation capacitor (i check the commutation capacitor,its ok).there is option potentimeter in serial with thermal switch,i check his value i found 5ko (in the drawing it writen 10ko!!)
also i give 80Volts in the illumination wire of dash display and it illuminate few second and return black.can be damged
can anybody help me
BEST REGARDS.
  • Posted 1 Jan 2014 21:38
  • Reply by bouzid_m
  • algerie, Algeria
Thank You
Appreciated greatly. Will let you know when i receive it.
  • Posted 23 Apr 2010 18:15
  • Reply by elektrodrive
Hello Elektrodrive,
I will send you an email with the fault code of an Komatsu FB15R-8. I hope it can help you.
  • Posted 23 Apr 2010 17:09
  • Reply by marc_b
  • ANTWERP, Belgium
edition #1235 - 19 June 2025
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
Crown CG33P5
Aichi SR10C1SM
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Rail King RK330
