Komatsu FG25ST-14 MIL light
Is there any way to turn off or reset the MIL light besides calling in the local Komatsu dealer? The truck doesn't seem to have any apparent faults and runs fine.
We tried the pedal dance but it doesn't turn the light off.
  • Posted 28 Nov 2012 22:27
  • By duodeluxe
  • United States
duodeluxe
if its not showing a code and theres no way to make it flash codes then yes, call komatsu
you can try the pedal dance and see if you can make it enter into mode2 (diagnostic mode)
there are several threads in the forum that discuss on how to enter mode2 using this method. Once in mode2 it should flash your error codes on the MIL light.
but keep in mind, if there is an error in the pedal position sensors you will not be able to obtain access into this mode using the manual method and will need to get a service tool or call komatsu.
  • Posted 6 Dec 2012 08:30
  • Modified 6 Dec 2012 08:46 by poster
So is my only option to call in my local Komatsu dealer?
  • Posted 3 Dec 2012 22:25
  • By duodeluxe
  • United States
duodeluxe
like most of these systems
if you use the pedal dance method to get into the maintenance mode to use the clear routine and the MIL does not clear then the problem causing that light to come on is still present.
You have to resolve the issue before the light will turn off.
  • Posted 29 Nov 2012 21:42
Deborah Baker Deborah Baker
