Komatsu FB15-12 (2007) servis manual
Hello friends.
Tell me, can anyone have instructions to repair or decrypt character symbols on the loader? Error Codes I have, but still burning symbols, the designation of which I do not know. Lit icon circle with 4 points on the left panel and the error 3012.
Thank.
  • Posted 21 Sep 2016 18:39
  • Modified 21 Sep 2016 18:41 by poster
  • By NavService
  • joined 15 Dec'14 - 13 messages
  • Ukraine, Ukraine
Sir how about the the error code fb15rl-12 code E 20 and E 13 can u plzz help me..
  • Posted 14 Jul 2021 13:10
  • By Dylan_Acjedo
  • joined 17 Aug'20 - 4 messages
  • Philippines
Dylan
3231Travel motor (Abnormal temperature]
  • Posted 5 Apr 2017 22:34
  • By niki_r
  • joined 8 Apr'08 - 16 messages
  • sofia, Bulgaria
Hello, help me, please.
Tell me, how to repair Error Codes 3231 in Komatsu FB15-12 (2008)
Thank.
  • Posted 13 Mar 2017 15:19
  • By pham_cao
  • joined 13 Mar'17 - 1 message
  • viet nam, Viet Nam
Hello Zhan, the symbol means that you have a travel problem (tire icon), for the error 3012:
1. Disconnect the battery connector and leave the
vehicle for 10 minutes.
2. Disconnect the motor cable from the U, V and W
terminals and measure with the tester between the
motor cable and P terminal and between motor
cable and N terminal. If leaked, remove or repair.
3. Confirm that no foreign matters exist on the P and N
terminals and around the U, V and W terminals.
(Check visually foreign matters on the CPU board.)
4. Confirm that the motor cables are correctly connected
to the U, V and W terminals of motor.
(The cables should be connected to the right and
left terminals without error.)
5. Check the travel (R) controller, travel (L) controller
and cargo handling controller. If abnormal, replace
it. (Replace the CPU board at the same time.)
6. If normal in the above check, replace the travel (R)
controller or travel (L) controller.
regards
marcb
  • Posted 22 Oct 2016 00:51
  • By marcb
  • joined 10 Jun'14 - 222 messages
  • ANTWERP, Belgium
VETTER Industrie GmbH
