Komatsu 4d95s engine running trouble
Hello everyone first of all I'm new to the forum. I'm a forklift dealer in th UK.
I have a FD 25 with an 4D95s motor. It's recently had reconditioned injectors, new rings and honed bores. With the new head gasket fitted, skimmed head and valves adjusted I started it up to find it ran poorly and struggled to rev up. I cracked the injectors and found that cracking no.1 made no difference to the engines running which suggested the problem being on that cylinder. When number 2, e and 4 were cracked the engine cut out. I compression tested 1 and 2 which had pretty much the same reading. I swapped 1 and 2 injectors around and the same problem.
Any suggestions? Also the fuel stop solenoid doesn't work and is stopped manually by cable.
Thank you.
  • Posted 20 Oct 2015 07:33
  • By kelvin_h
  • joined 20 Oct'15 - 1 message
  • Beds, United Kingdom
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SNORKEL A46JE
USD1
SNORKEL A46JE
