killing battery
changed starter cause it was draining batt and had alternator checked, it starts draining batt after driving for
awhile, starts up right away if you jump
  • Posted 22 Jul 2009 11:55
  • By gonzalo_v
  • joined 6 Jun'09 - 13 messages
V,
I would suggest that you remove the negative battery clamp and hook a 12 volt test light "in line" to confirm that you are pulling voltage from the battery. If the test light is lit without the key switch on then it means you have a current draw. If you see that you have a draw then you can begin to elimenate components by unplugging them to see if the light goes out. Usually you will find the alternator is the problem.
If you are not pulling voltage with the key off then you have another problem. I suggest that you check the voltage at the battery when running. You see about 14.25 volts there.
Steve
  • Posted 22 Jul 2009 12:19
  • By Forkliftt
  • Louisiana, United States
Still GX10
Still GX10 2000
Poland
EUR950
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Lift Tek Elecar
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Still GX10
Still GX10 2000
Poland
EUR950
USD1
