Jungheinrich Model is EPG 216K errors
I am a new poster so I hope I am in the right place...
Jungheinrich Model is EPG 216K, I need to decode error codes...19...35...135.
Also to reset yellow wrench light.
These codes seem to be part time and the truck can be reset and used by turning the main switch on and off (sometimes).
Thanks for any information
  • Posted 13 Sep 2008 09:54
  • By runnynose
  • joined 18 Jul'08 - 7 messages
  • British Columbia, Canada
Just chillin' out...
Hi Marqus.
I do think error code is "1d" It says 1 of the 3 steeing controllers "ELLE" has a wheel-sensor (potentiometer / encoder) failure. Check all 3 contollers for errorcode "d" to locate bad sensor. Maybe it can be adjusted. If you have never tried to adjust a ETV-Q, don´t try. It is only for skilled technician´s.
Regards, Max
  • Posted 20 Mar 2009 06:20
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Truck is from 2001
Driving stopped but mast was able to work. In display was written "Id".
  • Posted 20 Mar 2009 01:24
  • By margus_l
  • joined 27 Aug'08 - 11 messages
  • Harjumaa, Estonia
Hello Marqus. What problems do you have? How old is your ETV-Q? Do you have any error-messages?
Regards, Max
  • Posted 20 Mar 2009 00:44
  • By Fittermax
  • Denmark
Fittermax,
are you able to help me with Jung ETV Q20 problems too?
forkliftworkshop at gmail dot com
  • Posted 19 Mar 2009 19:13
  • By margus_l
  • Harjumaa, Estonia
Hello,
I double checked the label and it has FN 326 070 as the serial number. Is there another number printed somewhere else?
Manufacture date is 2005, and another number is under "option" SP GE110-480DZ. The only others are to do with weights, etc.
Regards,
  • Posted 23 Oct 2008 08:44
  • By runnynose
Hello,
I have been off a couple of days...
I will check for another serial number tonight.
Thanks and Regards.
  • Posted 22 Oct 2008 09:09
  • By runnynose
Hello.
Serial nr. is not correct. It does have another format like:80460804 or 91256897 etc! Do you have year of manufactory?
Kind regards
  • Posted 18 Oct 2008 18:32
  • By Fittermax
  • Denmark
Hello,
I double checked the model and it is EFG-216K...the serial
number is FN 326 070.
Thanks for any info on the codes.
Regards
  • Posted 18 Oct 2008 01:05
  • By runnynose
Hello...thanks for the reply.
I will check the model and serial number when I go to work
tonight and get back to you.
Again, thanks for the reply.
Regards.
  • Posted 17 Oct 2008 10:00
  • By runnynose
Hello There.
Do you meen EFG 216K? If so, please write serial number....
Kind regards
  • Posted 15 Oct 2008 20:04
  • By Fittermax
  • Denmark
Maxlion FD30
Maxlion ESD15M
Hyster
