jungheinrich fault codes
can anyone help we have a jung ke16 which gives fault codes of
18 39 81 83
does any one know whats they mean
regards keith
  • Posted 7 Jul 2011 00:33
  • By keith_t
  • joined 3 Nov'09 - 101 messages
  • essex, United Kingdom
thank you
nacsand_n
i will have to learn spanish to be able to read it but thank you very much
  • Posted 9 Jul 2011 03:16
  • Modified 9 Jul 2011 03:17 by poster
  • By keith_t
i've sent you some information about fault codes and lisa display.
Hope will be usefull for you.
Regards
  • Posted 8 Jul 2011 08:05
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
how do i access the controller through the display
  • Posted 8 Jul 2011 07:07
  • By keith_t
HI keith
Ok the 39 relates to incorrect truck type set and this makes sense with 81 and 83 as they relate to incorrect parameters set.
The 18 relates to armature current error.
Did you have the controller replaced? and after replacing some of these units the other errors occurred?
The best thing to do is first access the controller settings through the display and set the truck type to the type of truck you have, this should eliminate 39,81 and 83 errors. If there is any other problems with the unit or on the truck this may become clear after.
Also if you do require these controllers that can be arranged as i stock these units.
  • Posted 8 Jul 2011 03:31
  • Modified 8 Jul 2011 03:33 by poster
  • By elektrodrive
enquiries@elektrodrive.co.uk
yes it has the three dc controllers fitted in the back of truck
  • Posted 7 Jul 2011 03:40
  • By keith_t
Hi Keith
I cant seem to find a Jungheinrich KE16 on my version of Jeti...would this be the Boss version??
Does it have the 3 small controllers in the back similar to the EFG range? If it has the MP1514 controllers i should be able to get you the fault code list.
  • Posted 7 Jul 2011 03:37
  • By elektrodrive
Aichi SR10C1SM
Hangcha FLDCXT160
