Jungheinrich EJD 20 - 2004
Hi Guys,
I have a driving problem on a JH EJD 20-3 from 2004 (Walk-behind stacker). The driving stops at full throttle. The potentiometer goes from 0.9 at rest to 8.25 volts full throttle, but higher than about 8.00 volts the traction stops.
Are these vaules correct? Is this the potentiometer, or a problem in the calibration?
BTW. Now and then it drives good, but i didn't have my multimeter on it at that time.
Frits.
  • Posted 14 Jan 2010 20:19
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
The costumer finally told me it was alright to fix this truck. Replaced the throttle controller but same fault.
It turned out to be the interface card on the MP1510.
Thanks for your replies.
Frits.
  • Posted 30 Apr 2010 06:56
  • By frits_f
Error 6 on a Jungheinrich is almost always the throttle twist controller, this is a very common fault.
Truck will drive slow but when full throttle applied, truck stops and error 6 displayed or flashed
Check the wiring first and have a good visual inspection of the controller, specially if it has an anti-crush switch attached
  • Posted 28 Jan 2010 06:00
  • By john_n
  • joined 21 Sep'05 - 14 messages
  • Lothian, United Kingdom
Hi
I've been measuring the voltage once more: At 5V (to B-) it goes slow, 7,5 V is full speed, and at 7.75 it stops and flashes 6 times. I didn't order a new controller yet but now I doubt if it would solve my problem. It is indeed a MP1510 drive control. Are there any other measurements I can do? What should the supply voltage be?
Frits.
  • Posted 28 Jan 2010 02:26
  • By frits_f
Yeah right. oops.
frits.forklift at gmail dot com
  • Posted 22 Jan 2010 02:31
  • By frits_f
HI Frits
I could if I had your e-mail adress.
Regards, Max
  • Posted 22 Jan 2010 02:22
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Thank's for helping. Contact d-b-a@mail.com
P i s s Work, gone fishing
Hi,
The custumor seems to need time to agree with the repaircosts. Thanks for your replies. I'll let you know when I know more.
Fittermax: can you send me an e-mail? I've got a question for you about something else.
Frits.
  • Posted 22 Jan 2010 01:47
  • By frits_f
Travel switch current too great - travel function inhibited
Like say Fittermax you must have max 5V
  • Posted 15 Jan 2010 17:31
  • Modified 22 Jan 2010 21:14 by poster
  • By piotr_b
  • joined 3 Jun'09 - 41 messages
  • mazowieckie, Poland
HI.
6 blink : Output from speed-controller, when in neutral, is less than 0,05V or more than 1,8V. Maximum output from speed-controller should be less than 5 V. I think you have a broken / defective speedcontroller.
Best regards, Max
  • Posted 15 Jan 2010 17:27
  • By Fittermax
  • Denmark
ZA: 6 Blinks
  • Posted 15 Jan 2010 02:22
  • By frits_f
when truck stops what you have error in diode (haw many times red diodes blinks)???
This power MP1510C in this truck used max 5V. Now i check this info in truck.
  • Posted 15 Jan 2010 01:02
  • By piotr_b
Hangcha FLDCXT160
Elwell-Parker ESI500-36
Noblelift
Hangcha FLDCXT160
Noblelift
