Jungheinrich EFG425K
Hi. I am looking for Troubleshooting Guide and Electrical schematics for model - EFG425K. Is there any one out there who can assist me, please.
  • Posted 16 Nov 2012 10:08
  • Modified 16 Nov 2012 14:45 by poster
  • Discussion started by shabir_p
Showing items 1 - 15 of 17 results.
Hello
Thanks for your help ,
By opening the unit's controller , we find that the LINE (V) is damaged we need to change mosfet's IRF3415S.
When i check with Jungheinrich programmer (scanner) the brake switch is always closed , it never works.
Mybe its the cause of problems.
Model is EFG425K. 2010 Year.
Best regards
  • Posted 21 Jun 2019 04:22
  • Modified 21 Jun 2019 04:27 by poster
  • Reply by Miriloc
  • Alger, Algeria
I know that on the 3 series if your brake fluid or pedal switch can't remember which one is faulty it stops drive bit doesn't throw up any errors. Might be worth checking your brake pressure switch/fluid switch if ot has one.
  • Posted 21 Jun 2019 04:16
  • Reply by elektrodrive
enquiries@elektrodrive.co.uk
14 is usually field circuit failure on the motor nor control unit faulty and 50 is a short on the motor. So if motor is short and faulty most probably damage the controller also. What model is your truck. Also perhaps create a thread post with the details so doesn't hijack another thread as could get confusing
  • Posted 21 Jun 2019 04:14
Jungheinrich
  • Posted 19 Jun 2019 13:49
  • Modified 19 Jun 2019 13:55 by poster
  • Reply by Service_T
  • Kansas, United States
Hi dear
Please ,
i'm actually facing an ERROR 055 & 014 on EFG425K.when turn on forklift , lift mouvements works properly , but by pressing accelerator the errors appear on display. And main contactor stop.
Then forklift stop all mouvements (tract &Hydr).
Can anyone help to find out about the fault or at least tell me what code 055 & 014 reffers to?
2010 year.
Thank's.
  • Posted 15 Jun 2019 02:28
  • Reply by Miriloc
  • Alger, Algeria
mirilocdz @gmail.com
Sounds like you have a problem with the foot potentiometer....
  • Posted 2 Jan 2013 05:09
  • Reply by powerlifter
  • united kingdom, United Kingdom
My mail is in profile,I was think on main switch or emergency switch.Is it vehicle with multipilot or solo pilot for hydraulic?
  • Posted 27 Dec 2012 01:51
  • Reply by nemanja_k
  • serbia, Serbia
Hi King. I checked the steering arrow, it works correctly. As for the main switch, is this the one under the foot pedal? If you have an email, I can send you the pictures.
Thanks
Merry Christmas and a Prosperous New Year.
  • Posted 26 Dec 2012 13:46
  • Reply by shabir_p
Ok I am wait to here what you find.
  • Posted 6 Dec 2012 07:22
  • serbia, Serbia
Thanks King. I will check and let you know.
Shabir
  • Posted 4 Dec 2012 09:04
  • Reply by shabir_p
Is it steering arrow on display turns same like wheels?If does check one more thing, under main switch you have tree bypass connections look are they stay ok one of them is traction cut off.Give me more details so I can help you better.
  • Posted 4 Dec 2012 04:30
  • serbia, Serbia
No error codes. Switch clicks in and out. No traction, no hydraulic lift etc. steering guide arrow on dash will show position of steer tyres.
Thank you
Shabir
  • Posted 28 Nov 2012 18:09
  • Reply by shabir_p
does an error code show up when you press the accerator pedal?
  • Posted 28 Nov 2012 15:34
  • Reply by swoop223
Ok for this state do next.First when you start truck dont touch hydraulic,just seat on truck start him and when sistem starts press accelerator pedal.In this moment if you dont have any error check pedal-first close micro switch than go potentiometer,look is it wiring ok.Second look sensor for steer back of the truck down of counterweight of course wiring and brake micro switch.Look on display do you have arrow direction when you give command.Like last problem stays interface board but for that problem I must to give you more data to check,so look this first and tell as what you do.Of course GOOOOOD luccccck
  • Posted 28 Nov 2012 04:33
  • serbia, Serbia
Hi. There is no error code showing. The forklift will does NOT have traction (forward or reverse). Forklift starts and will lift, tilt and sideshift as long as I DON'T press the throttle pedal.
The serial number is FN346760 and Model number EFG425K.
My Email is [email address removed]
Thank you
Shabir
  • Posted 27 Nov 2012 09:38
  • Modified 27 Nov 2012 09:41 by poster
  • Reply by shabir_p
Linde C4230TL5
TCM FHD105Z
Mobicon 2T
Taylor TXB180S
Harrisburg, SD, United States
Ottumwa, IA, United States
Wentzville, MO, United States
