Hi all , anyone have the code for set the service maintenance light of in the display of this truck ? i need the 4 code numbers for the display settings
Regards
Hi Diesel123
Do you think removing the battery from the display unit will reset the password back to factory settings aswell.
JH have changed the password on this one I have.
HI all
EFG 535 MP
Helps to remove the battery display?
Or where to buy sn 50125023 Programmer, hand held
Hi Piotr , yes i know i can used can-usb but they software program jungheinrich i have not.
Older versions of display you van take the bridge on the print behind the display for reset the truck to fabric settings , this displays have not and is a newer version.
the local dealer have change the setting now.
I used converter can-usb what buy in market and normally change all parameters in jh truck
Unscrew the dash and remove the small "watch type" battery for 30 seconds. Refit and it should have turned the light out.
should be 1234 need to access first with buttons space flashes then enter 1 move to next space 2 etc then enter think this is the boss , komatsu version also plays tunes but cant remember how to set : )
1234 or 4321 when light light service key.
If it flashes only helps PC.
That is my experience.
is this the display under the steer wheel with hour meter then eggtimer snail buttons etc on rhs
I'm not sure, you can do it without a laptop/JUDIT. I've checked the servicemanual and it tells nothing :-(
Regards, Max
