Jungheinrich code 68 or 168 help needed.
Model EFG 316K shows codes 68, 168 and has no travel or lift. Any help would be wonderful. Thanks
  • Posted 22 Jul 2010 05:27
Well I fixed the broken wire at the plug to the seat switch and all is well. Thank you.
  • Posted 23 Jul 2010 08:22
Error 168 is similar to error 68. But that is about 3 or 4 interface.
  • Posted 22 Jul 2010 21:54
  • By mosu_r
  • joined 22 Jul'10 - 12 messages
  • olt, Romania
Thanks powerlifter, sounds easy enough, I'll jump right on it in the morning.
  • Posted 22 Jul 2010 07:21
Hi mrfixit
Code 68 = Safety switch wire Component 12 13 14 15, Display text DEADMAN, Cause/Action = Check wire connection to safety switch (deadman,seat switch ); replace safety switch. Effect
Code 168 = General pulse width modulation (pwm) error,Component T, Display text ERR + node number + error number, Cause?Action = Parameter error effect Travel disabled.
  • Posted 22 Jul 2010 06:51
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
Maxlion FB25LI
Terberg YT222
