JUNG ETM 14 headache truble
A custem have some old Jung_ reach truck
it sotp work with some code sometimes;
PUMP42
PUMP43
ELECTORC46
ELECTORC47
ELECTORC38
ELECTORC34
ELECTORC27
10
The troubles are so headache.
does anybody have the old fault code list
wait for you help.
King regards
  • Posted 25 Aug 2012 16:38
  • Modified 25 Aug 2012 16:50 by poster
  • By shar_k
  • joined 30 Jun'12 - 37 messages
  • SH, China
E-mail:kunshar@qq.com;xiakun223@163.com
Thank you !
I know one is the multipilot.
one is main board (motor is OK).
one I exchange the multipilot frome another,it's OK.(the cable to the valve is break)
One exchange the main board,also OK
Could you give me this type the error list?
if next time they will display another error.
Best regards
Kun
  • Posted 27 Aug 2012 10:36
  • Modified 27 Aug 2012 10:40 by poster
  • By shar_k
  • SH, China
Hello.
"Electrodrive" is right. It is the older mosfet combi controller.
Error:
42. Shortcircuit on output stage
43. Error in multipilot/joystick. Centervoltage not OK. Wiring or
poti broken.
46. No field current. Bad/burned controller.
47. Minimum field current not OK.
38. Check main contactor. This error is normally related to
other errors. Safety !!!
34. No communication with controller....
27. Unknown to me. Is not in my error list.
10. Multipilot activated during start up. It is proberly a bad
poti inside multipilot (or broken wire to multipilot)
All this errors seems a litle strange since they are not related. Check for humidity and dirt on all pcb's. Check connections on hydraulic controller (top pcb on power-steering) and use LISA to check if multipilot is OK.
Regards Max
  • Posted 27 Aug 2012 02:53
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
three trucks
one can move,
My boss buy from a supermarket depository.
  • Posted 26 Aug 2012 23:44
  • By shar_k
  • SH, China
Sounds like the MP616 or 614K controller. Jungheinrich soon moved away from these i have been told, due to the problems with them. I would guess due to the number of error codes that are being displayed, its a good chance the problem is in the main pcb which covers both traction and lift.
  • Posted 26 Aug 2012 23:26
  • By elektrodrive
  • joined 2 May'08 - 740 messages
enquiries@elektrodrive.co.uk
Hi Trevb
it have a larger printed board of steering,above it it is the hydraulic valve controle board.Tractor and pump in a larger board,under it is some FET model.
  • Posted 26 Aug 2012 13:05
  • Modified 26 Aug 2012 13:06 by poster
  • By shar_k
  • SH, China
what type of controllers do you have
  • Posted 26 Aug 2012 07:46
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
IMHX to become a biennial event Birmingham, United Kingdom
October 8-9, 2025 - Twickenham, United Kingdom
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
