JUDDERING IN REVERSE
Hi
Our Hyster runs great in forward, but judders back in reverse at 1/4 speed at best. I've swapped the solenoids over to no avail. The housing the solenoids fit into looks like it may be fluid filled? So I didn't want to progress before asking for advice.
TIA
  • Posted 28 Dec 2013 02:21
  • By cam_s
  • joined 28 Dec'13 - 4 messages
  • northeastern, Cyprus
Ok thanks, I'll.get it changed.
  • Posted 30 Dec 2013 06:57
  • By cam_s
First thing to do is change the oil and filter it should be JD40 spec oil (tractran 9) ive seen plenty of hysters running standard ATF and the clutch packs always fail I would suspect that the shuddering is being caused by a damaged clutch pack this is common when running atf
  • Posted 30 Dec 2013 06:33
  • By lifter01
  • joined 4 Jul'09 - 463 messages
just checked it ATF
Any thoughts please
  • Posted 30 Dec 2013 02:01
  • By cam_s
I'll have a look tomorrow. If I remove the housing the solenoids are going into, is it going to be messy?
Ta
  • Posted 28 Dec 2013 06:36
  • By cam_s
What spec oil has it got in it is it red type ATF (dexron 2)?? or a light brown colour??
  • Posted 28 Dec 2013 05:59
  • By lifter01
Taylor TX175
New - Sale & Hire
Unicarriers FHGE35T5S
ROYPOW
Taylor TX175
New - Sale & Hire
