Joystick replacement
Hello. Bought a linde h35d- 2008- H2X393W01894 and have some error codes regarding the joysticks (T235 - T236 - L222)
Hour count : 9620
Do you think I should replace them and if yes, does a linde technician have to calibrate them etc? Or can I do it with close to zero experience?
Any positive experiences with contact cleaner?
Thanks in advance and thanks for all the great older posts I've read on this site.
  • Posted 17 Jun 2023 10:46
  • By nik_fry
  • joined 17 Jun'23 - 2 messages
  • Norway
Code L222 is one of the joysticks not centered during engine start. With this code you will not have hydraulic functions. Try to center the joysticks when starting. If you are replacing the joysticks stretch the boot around the front two corners and the back corner last, then use the flat part of a flat blade screwdriver to push the boot the rest of the way into the grove. You will usually not need to calibrate.
It is important to have the boot on correctly or dirt gets underneath it and wears out the joysticks again.
  • Posted 3 Sep 2023 13:05
  • By IFD45
  • joined 28 Feb'13 - 31 messages
  • Wisconsin, United States
IFD45@mail.com
I always put a 6mm flat washer on each bolt under the joystick (between the joystick and armrest) to space the joystick up a bit, otherwise you cannot get the rubber boot to go back into place. I dont understand how they manage to do it from the facctory :)
  • Posted 29 Jun 2023 07:07
  • By andrew_k
  • joined 17 Mar'07 - 364 messages
  • England, United Kingdom
Thanks.
I've purchased all new joysticks, do you have any tips or advice for when I install them?
  • Posted 28 Jun 2023 07:39
  • By nik_fry
  • Norway
T235-236 are direction switch faults, it probably just needs a new direction lever.
L222 is a joystick, you can usuallly just change them without calibration but I have the laptop so I always calibrate them.
  • Posted 18 Jun 2023 08:07
  • By andrew_k
Terberg RT223
UN Forklift FBRP15NQZ2
Terberg RT223
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
