Jhungheinrich ETV 325 Showing Error 68 and Error 124
Hi All,
One of my client have ETV 325, Serial 91064625. Truck showing errors 124, error 68 and warning 02 on display "On Board Computer". Please help me for this.
  • Posted 22 Feb 2023 20:20
  • By Syed
  • joined 14 May'15 - 196 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
You get new errors while disconnecting because these modules are not option modules. CAN resistance will also change on certain can line while disconnecting whole control box, thus it will produce new errors.
I would start from sensor, isn't it and inductive sensor reading mast reach position? is the light on the sensor? Does the sensor get the supply voltage?
  • Posted 26 Feb 2023 20:42
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
I disconnect all reach and mast sensors but still showing error 124 "Int 6, MFC 2 EEPROM no reply". The error is going to shift from 124 to 34 when I disconnect the black control box which is near to the main hydraulic block and again reappear 124 after reconnecting the black control box.
In past the mast wiring harness which is for sideshift function and camera function was damaged. Is black control box is faulty? Or the error 124 only due to the sonsor?
  • Posted 26 Feb 2023 10:11
  • By Syed
  • Sindh, Pakistan
02 Overvotage - measure battery volt, check battery fluid level.
68 deadman switch, wiring
124 Mast reach sensor, check sensor, wires
  • Posted 26 Feb 2023 04:57
  • By Tanel_M
  • Estonia
SMV (Konecranes) 20-1200B
SMV (Konecranes) 33-1200C
