Komatsu FG25T-16:
Is 900 lbs capacity right?
Hello I'm going to look at a used fg25t 16 tomorrow. They sent me a picture of the serial plate and I was wondering why it says 900 lbs in the capacity block. I cant see the right side of the plate in the picture so I don't have the full serial number or the last digit of the date. First three of the serial number is 213 and the first three of the date is 200 model is fg25t-16 type I think says clp truck weight says 9550 I'm just curious why it only says 900 lb for the capacity. They told me it has a 20 foot mast hight so I'm not sure if that matters.
  • Posted 22 Dec 2023 06:43
  • Discussion started by Tim_Russo
Scott is correct, 20ft is a 240" Quad mast and that will derate your capacity quite a bit.
  • Posted 28 Dec 2023 00:12
  • Reply by Jeff
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
I read your post the fg25 means it will lift 5000 pounds but if you look on the plate it would tell you at the max height it will only lift 900 pounds sounds like this truck has a quad mast on it if it lifts 20 feet. This is what I am thinking. Hope this helps.
  • Posted 23 Dec 2023 12:53
  • Reply by Scott_
Scott
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
Mitsubishi FGE35AT
Terberg YT220
