Intermittent Lift
Working on a 30RCTT-190 for first time. Lift moves forward and reverse, tilt in and out works, Lift sometimes works, but not often. Replaced lift contact plates and didn't work right after that but next day it worked and for the next few days, then once in a while... I'm thinking it could be electrical since it works sometimes, but looking for advice on what to try next. Thanks for the feedback!
  • Posted 25 Nov 2021 07:10
  • By Tony_T
  • joined 25 Nov'21 - 3 messages
  • Minnesota, United States
_TT_
that is a 36 volt battery and you said that you see 12v on the meter before you fire up a motor ?
the battery is way too low state of charge !
where are you connecting your meter leads ? directly to the cables ?
  • Posted 15 Jul 2022 17:19
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Before reads 12v and during lift reads 10.25v. Water level is good.
  • Posted 15 Jul 2022 03:59
  • By Tony_T
_TT_
You need to test the battery voltage before & after you select a hydraulic function, watch your meter to see what the voltage is when you are standing still versus when the Lift Motor is running.
Pull the battery out of the compartment and remove cell caps.
I'll bet it needs water, because everybody ignores water levels.
  • Posted 13 May 2022 07:29
  • Modified 13 May 2022 07:30 by poster
  • By LaGrange
Replaced the Brushes and raise switch.. no change still lifts 5% or less of the time. Tilting the mast to straight vertical seems to help the frequency of the lift, but still doesn't lift very regular at all. Other ideas?
  • Posted 12 May 2022 02:30
  • By Tony_T
_TT_
I would look at the raise switch and the lift motor brushes. Make sure the brushes are not worn or stuck in the brush holders.
  • Posted 11 Dec 2021 16:52
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Maxlion FB30LI
Terberg YT222
