Intermittent drive both forward & reverse
Hi folks, got a tlt35d 4x4 which won't select forward or reverse occasionally. If you switch off n restart still won't move, u just keep shuttling F/R lever then off it goes. Sometimes b fine for a while then other times just sits there or will select one direction but not other???
  • Posted 1 Jun 2022 18:56
  • By Razor
  • joined 29 Jul'19 - 2 messages
  • United Kingdom
On the left panel beside the steering wheel. The relay in the fuse box closest to the right top is your brake relay. Few times it has come loose cause no fwd/rev.
  • Posted 2 Jun 2022 00:52
  • By grant_c
  • joined 12 Aug'16 - 27 messages
  • Manitoba, Canada
Noblelift
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
UN Forklift FD25T-C2JM1
UN Forklift FB25N1QZ1
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
