Impco Model J LPG Regulator Replacement -- Need Help...
I just bought a new Impco Model J Regulator. Upon inspection of the old one vs the new one; the old one has W.C..2 LBS embossed on it whereas the new one has W.C. 0.08 LBS embossed on it.
Would there be an issue in using a regulator with a different pressure rating?
I cannot seem to readily find an Impco Model J with 0.2 LBS Water Column (Aka Red Spring)....
Thank you!
  • Posted 25 Aug 2017 05:28
  • By joseph_r
  • joined 14 Feb'14 - 6 messages
  • Washington, United States
Got the new regulator installed and it runs great!
  • Posted 26 Aug 2017 04:36
  • By joseph_r
Well then in that case it will probably work better!
  • Posted 25 Aug 2017 10:51
  • By joseph_r
I think it is supposed to have a.08WC one. At any rate, it should work fine.
  • Posted 25 Aug 2017 07:42
Terberg YT220
Nagano NUZ090D
Terberg YT220
Nagano NUZ090D
REPOWERTEK Inc
