IGN fuse keeps blowing
The 7.5A IGN fuse keeps blowing as soon as the ignition is turned on. A multimeter indicates there is a 5 ohm resistance between the fuse and ground and continuity (dead short?) from fuse to ground. The wiring is a mess in these things and an experienced forklift tech tells me they are infamous for having wiring issues. If I pull the other fuses and check, it seems several of them have continuity to ground on the output side with good +12V on the buss side, but none of the other fuses blow. Even the 10A fuse output seems to have continuity to ground. HELP!
  • Posted 17 Jun 2021 02:40
  • By Kenneth_Cohn
  • joined 17 Jun'21 - 2 messages
I have same issue.
did you fix your problems?
  • Posted 16 Sep 2023 05:56
  • By jun_kikuchi
  • joined 16 Sep'23 - 3 messages
jk
Thanks for that advice. The Toyota wiring diagrams suck!
  • Posted 22 Jun 2021 02:22
  • By Kenneth_Cohn
There might be a short circuit within the Ignition Switch Wire Harness; Positive volts and Negative volts are contacting each other and blowing that fuse.
Short Circuits are very aggravating to search for and locate.
You'll need to take a good look (if your forklift has these) at the Headlights wire harness and the Strobe Light wire harness and see if the wires have been chafing against the chassis or Overhead Guard, which of course
would cause a Short Circuit.
  • Posted 20 Jun 2021 14:38
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Still GX10
Still GX10 2000
Poland
EUR950
Rail King RK330
Still GX10
Still GX10 2000
Poland
EUR950
Rail King RK330
Stu Jacover Stu Jacover
Chief executive officer, TVH
