Idle issue only when applying 75% throtle or move
If you are having an idle issue only at high RPMs before changing the fuel components make sure the check engine light is working. If this light bulb is burnt out it will give the early K21 engine a host of problems that lead to a fuel systems failure but its not.
  • Posted 30 Apr 2019 05:23
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
Terberg TT223
SMV (Konecranes) 16-1200C
edition #1237 - 3 July 2025
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
