Hyster W40Z B218 Walkie - Code AL10
Code AL10 on a Hyster walkie jack. L.E.D. flashes no lift or travel. Replaced controller and same issue. Codes from zapi no help. Any one have the service manual pdf to this. Have checked all connections, contactor, and batteries. I am stumped. Have any ideas?
  • Posted 9 Feb 2012 23:30
  • By mikeco
  • joined 27 Dec'10 - 3 messages
  • Colorado, United States
Before condemning the controller.Check the condition of the drive motor brushes. Often a dirty armature will cause this code. Also check the condition of the batteries
  • Posted 16 Oct 2018 01:14
  • By seaborn_a
  • joined 16 Oct'18 - 6 messages
Hello - did you solve you issue with AL 10? I am having the same alarm and when I lower my handle and power up I first get an AL 04 alarm. Please help
  • Posted 20 Sep 2018 07:17
  • By wayne_d
  • joined 20 Sep'18 - 2 messages
The manual also says the LED should not be flashing. In my experiences I have found AL10 with flashing LED to be a battery or cable issue, or voltage drop at controller B+. If controller doesn't get battery voltage on start up it will drop out.
  • Posted 15 Feb 2012 13:01
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
We have the same problem. We called in a tech from a hyster place, and they gave us a bid of around 2500 to replace the main controller board, handle, and the driver board in the handle. So, we decided to replace the main board, and it still has this problem. It would be good to find out what AL10 even means? Does anyone have the code definitions?
  • Posted 15 Feb 2012 07:56
  • By ScottOgden
  • joined 15 Feb'12 - 1 message
  • Utah, United States
Don't know if you still need the info on this but here is what the manual says, check the drive motor, pump motor, solenoid, brake coil, lift solenoid, lower solenoid. It says to disconnect all of the above, then hook up one and turn on, then another until fault shows up. Check for fields shorted in drive motor.
  • Posted 14 Feb 2012 14:32
  • By meliftman
Liftman
Retired
Elberta, Al.
Enforcer FLBAXT25
Crown WP302020
F. Uchiyama
