Hyster Vs Doosan Vs Still Vs BT Reach Truck
Have to pick a Reach Truck out of these makes but was wondering if anyone had any feedback on what truck is the better one out there. They are all roughly the same price with Doosan being about 15% Cheaper. Hyster does have the advantage of being available immediately but if we need to wait for a better machine that is something I'd consider.
Not for a heavy warehouse operation, looking at the 1.6 / 1.7 Ton Models.
  • Posted 15 Jun 2017 00:17
  • By roh_p
  • joined 15 Jun'17 - 3 messages
  • Dubai, United Arab Emirates
I am familiar with the U.S Yale/ Hyster reach, they are a good truck. Not sure how the are set up in middle east.
  • Posted 16 Jun 2017 23:07
  • Modified 16 Jun 2017 23:08 by poster
  • By BREWSKI
I have no experience of the Hyster so cant comment.
  • Posted 16 Jun 2017 01:57
  • By Forkingabout
  • england, United Kingdom
Thanks. How does the Hyster compare against the BT ? Reason being, I need to wait for a few months for delivery of the BT, whereas Hyster I can grab off the shelf here.
  • Posted 15 Jun 2017 14:52
  • By roh_p
Sounds like a BT Reflex RRE 160 with 6.3 triplex mast would be ideal the job.
BT also do a cheaper Reflex B series which is a basic reach truck ideal for small companies who just want a simple reach truck to move / stack stuff about - no idea if its available in your part of the world.
  • Posted 15 Jun 2017 14:50
  • By Forkingabout
We're only going up to about 6 MTRs and the Loads at that height will be under 1 Ton. The max load on the racks is 1.6 Ton which will only be at the bottom levels. From step one onwards it is less than a Ton. The usage is going to be light, probably an hour or two a day so don't expect failures soon but all of them have reasonably good support and dealer service out here.
  • Posted 15 Jun 2017 14:18
  • By roh_p
How high are you lifting the load & how heavy is it?
Might be better to have a little extra residual weight capacity available from your choice of truck.
BT RRE Reflex you could pick between 1.6, 1.8 or 2.0 ton versions for your application.
Whats the dealer service & parts back up like for all 4 of your choices?
No point buying a truck if the engineer / parts back up then leaves you waiting.
  • Posted 15 Jun 2017 01:52
  • By Forkingabout
The dot-com bubble, a period of large and rapid investments in internet-based companies, peaked in 2000 and saw the Nasdaq Composite index rise by 579%. Then the bubble imploded. As the value of tech stocks plummeted, cash-strapped internet start-ups became worthless and collapsed.
GemOne
September 23-25, 2025 - SÃO PAULO, Brazil
October 15-16, 2025 - Las Vegas, United States
November 25-26, 2025 - Singapore, Singapore
