Hyster S80XM no start?
Working on a Hyster S80XM series Foo rolls over not firing Replaced the coil same issue.Any tid bit will help
Thanks
  • Posted 29 Jan 2011 03:27
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
The simple things in Life are the greatest rewards!
I sent the mail 2 pdf. is correct?
Where is the ignition module?
check the power CKP CMP ICM
  • Posted 30 Jan 2011 20:54
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
I remove the spark plug wire and no spark.I have a tester with a lamp between the spark plug and wire to cap. There is power to the coil pack. there are two plug conectors plus the main wire to cap.
geroi send a email to my mail towmotor at hotmaildotcom
  • Posted 30 Jan 2011 03:54
  • By LOGIC
S3.50-5.50XM (S70-120XM) [E004, F004]
F004 module is the Ignition coil.check the pin c Ignition module
pin c / yellow18 / power of ECM
see post
  • Posted 29 Jan 2011 17:47
  • Modified 29 Jan 2011 17:58 by poster
  • By geroj
  • Krivan, Slovakia
Hi Logic ,
Reading through earlier posts I think you may have an ignition module failure probablem, module will be found in the distributor under the cap and rotor arm, but first check to see if you have a spark pull a lead of a plug stick a spark plug in it lay it on the rocker cover and turn engine over if no spark. check ignition mod to see if wires have come of or try another module.
Titus
  • Posted 29 Jan 2011 06:05
  • By Titus
  • joined 6 Jul'10 - 185 messages
Tusk 500PGH16
Manitou MH25-4
