HYSTER R30XM2 LIFTING PROBLEMS
Has anyone come across this problem on this truck where you have to lift all the way up turn off the key then back on and lower the truck all the way to reset truck? What would cause this problem?
The problem is truck goes into limit travel and won/t reset till you preform what is described above.
  • Posted 24 Jun 2009 07:35
  • By ben_g
  • joined 12 Feb'08 - 60 messages
hi edward t I will see if that is what may be causing this problem thanks.
  • Posted 8 Jul 2009 22:50
  • By ben_g
sounds like a height speed limiting switch (on the mast) is not working correctly, maybe the upper switch is closed when the lower one is open, or vice-versa.
  • Posted 8 Jul 2009 20:27
Has anyone come across this problem?
  • Posted 8 Jul 2009 08:10
  • By ben_g
Unicarriers FHGE35T5S
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
USD1
