Hyster PSI engines
I'm hoping someone can clarify which engines Hyster/Yale is using for LPG trucks at the moment. In the Hyster 5000lb tech guide it states it is a PSI 2.4 engine. When I go to PSI's website that sure looks like a Mitsubishi engine in the 2.0 and 2.4 displacement. So I have people telling me Hyster uses a Mazda engine with a Kubota 2.5L LPG as an option. Can anyone confirm to me what engine is standard in a 5000 lb cushion hyster and what is optional?
  • Posted 25 Aug 2016 01:00
  • By racingxr7
  • joined 27 Mar'15 - 12 messages
Good info! Thanks!
  • Posted 4 Sep 2016 04:09
  • By racingxr7
Mazda engine was discontinued at the end of 2014, so the Mistubishi-based PSI engine is the new standard.
I've got about a dozen of the PSIs in service now,The first is just now hitting 5000 hrs and we're in the process of changing the timing belt.
Unlike the Mazda, these are interference engines, so timing belt maintenance is critical. And as you might expect, they are generally a little more complex to work on than the old Mazda, but nothing extreme.
Only problem we've had with them so far is an o-ring on a coolant tube that seems to fail on all of them. They'll start to weep coolant from under the exhaust manifold. Fairly easy repair where a Viton o-ring and a little copper RTV have proven to be a robust solution.
  • Posted 2 Sep 2016 22:20
  • By Beeker
  • joined 27 Sep'12 - 32 messages
  • Indiana, United States
The PSI engine is a modified Mitsubishi. PSI buys the bare block and head and retools it to their standard. Not sure what the changes are but it is different than the stock engine. The Kubota is the optional engine.
  • Posted 25 Aug 2016 01:19
  • By BREWSKI
Crown RR5225-30TT321
Terberg YT222
Terberg YT222
