Hyster J1.80XMT - Water ingress in AC drive motors
Hello, I have been to a few Hyster J1.80XMT trucks recently that are all suffering with water ingress into the AC drive motors and throwing up codes. A strip down of the motor, clean out the rust and replace the encoder is fixing the fault - but I cannot see how or where this water is getting into the motors. Would like to be able to prevent ingress to avoid future issues.
Any ideas? Common issue on these machines?
Cheers,
Dan
  • Posted 3 Sep 2019 00:26
  • By BFT8679
  • joined 26 Apr'18 - 8 messages
  • Berkshire, United Kingdom
Thanks Dan, You were spot on. Thanks again for your help.
  • Posted 14 Oct 2019 02:23
  • By SMcG
  • joined 18 Feb'18 - 30 messages
  • Angus, United Kingdom
Hello SMcG, thanks for your reply. We eventually found the ingress was coming in via the wiring grommet in the top of the motor. We have made attempts to seal this up as best as possible.
Regarding code 6, I have this listed as "Request traction function while forward and reverse switches are opened." Code 7 is "Accelerator input voltage too high on power up."
Code 6 normally comes up when you have left it in drive, got off the seat and then get back on and attempt to drive without resetting direction lever into neutral first.
Cheers,
Dan
  • Posted 4 Oct 2019 18:19
  • By BFT8679
Hi Dan, We have the very same problem, Remove strip and clean the motor, replace the encoder bearing, the only other thing that we picked up when checking the motors was the cut out fitted inside the windings was faulty, just got a new cut out and fitted it external on with araldite.
refitted and job done.
We have a new fault this morning code 6 high throttle voltage? Any ideas on this one.
  • Posted 4 Oct 2019 18:00
  • By SMcG
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
Advance CS7000
Illinois, United States
USD8,000
