Hyster H450HD fault codes
Is someone able to provide me with some info on 2 Hyster Fault codes that are displayed on my H450HDS
E0559
E2249
Thanks in advance,
Leighton
  • Posted 9 Dec 2017 05:00
  • By leighton_r
  • joined 17 Oct'15 - 3 messages
  • British Columbia, Canada
thank you, problem solved, we did as told and found the problem in a quick conection hose just before the fuel pump.
  • Posted 3 Jul 2019 06:21
  • By Alejandro
  • joined 29 Jun'19 - 2 messages
  • Mexico
x
I would start with checking the voltage at the rail pressure sensor. Should be 5 volts. If voltage is good you could try a new pressure sensor. If that does not fix it you have a delivery pressure problem.
  • Posted 29 Jun 2019 06:30
  • By BREWSKI
Hi, I know its been a while, i have this problema, we serviced the pump and inyectors and the problema is still there, how did you solved this,
Thank you
  • Posted 29 Jun 2019 00:21
  • By Alejandro
  • Mexico
x
Right on thanks just headin there in an hour will update results
  • Posted 9 Dec 2017 06:13
  • By leighton_r
First code is injector metering pressure reading low rail 1 (moderate).
Second code is exactly the same except Not moderate, but extreme.
  • Posted 9 Dec 2017 05:56
  • Modified 9 Dec 2017 05:57 by poster
  • By BREWSKI
edition #1281 - 14 May 2026
Taylor TX175
New - Sale & Hire
SMV (Konecranes) 20-1200B
Taylor TX175
New - Sale & Hire
