Sw3 Is a buttom. Exist 3 buttom for operator. Upper buttom sw1, medium buttom sw2, lower sw3. Those buttoms are close to the display.
Probably That buttom Is broken.
Foro More información [email address removed]
I can send you a picture.
My english no Is very well but you can understand to me
Hello.
Maybe you have services manual for forklift hyster 3.0??
I Will thanks to much...
Hi,
Many thanks for your answers and helping! Could you explain what is SW3.
Unfortunately we haven't got any wiring diagram or work booK.
Display Eror
『Errd000』Data Receiving Time Out Error
『Errd001』Communication Data Malfunction
『Errd002』EEPROM Reading Failure
『Errd003』EEPROM Writing Failure(Hour Meter)
『Errd004』EEPROM Writing Failure(Controller Comand)
『Errd005』EEPROM Reading Failure(Controller Comand)
『Errd006』Lamp burned (Charge Lamp in the Display)
『Errd007』Fuel Meter Open Circuit
『Errd008』〃Short Circuit
『Errd009』Water Temperature Meter Open Circuit
『Errd010』〃Short Circuit
『Errd011』SW1(>Button)Error
『Errd012』SW2(<Button)Error
『Errd013』SW3(MButton)Error
Option Error
『Errc 50』Hydraulic Pressure, Steer Axle Sensor Power Line Failure Short Circuit
『Errc 51』〃Open Circuit
EEPROM Malfunction (EEPROM Aria)
『Errc 60』Maintenance
『Errc 61』Truck Setting
『Errc 62』Steer Axle
『Errc 63』Password
『Errc 64』Option
『Errc 65』External Option
『Errc 66』Controller Error
『Errc 67』Display Error
『Errc 68』Operation Management
『Errc 69』Hour Meter
Error Codes 4/4
Controller
『Errc000』Forward Solenoid Short Circuit
『Errc001』〃Open Circuit
『Errc002』Reverse Solenoid Short Circuit
『Errc003』〃Open Circuit
『Errc004』Mast Lowring Solenoid Short Circuit
『Errc005』〃Open Circuit
『Errc006』Mast Unload Solenoid Short Circuit
『Errc007』〃Open Circuit
『Errc008』Nothing
『Errc009』Nothing
『Errc010』Start Relay Error Short Circuit
『Errc011』〃Open Circuit
『Errc012』Pick-up Sensor Error Short Circuit
『Errc013』〃Open Circuit
『Errc014』Steering **** Misalignment Solenoid Short Circuit
『Errc015』〃Open Circuit
『Errc016』Steering Sensor Error adjudication
『Errc017』Nothing
『Errc018』Steer Axle Sensor Error Short Circuit
『Errc019』〃Open Circuit
『Errc020』Failure of F/R Switch or Neutral Switch
『Errc021』Nothing
『Errc022』EEPROM Error
『Errc023』Communication Error
『Errc024』CAN Communication Error
『Errc025』Option Hydraulic Pressure Sensor Defect Short Circuit
『Errc026』〃Open Circuit
『Errc027』Battery Voltage Decent
『Errc028』Nothing
『Errc029』Nothing
『Errc030』Steering Sensor Variation Malfunction
『Errc031』Steer Axle Sensor Variation Malfunction
『Errc032』Steering Wheel Number of Rotations Malfunction
