Hyster h1.8ft fault codes 524215-3 and 51-7
The truck will not start and can't find values to set tps
  • Posted 16 Feb 2024 20:33
  • By Dave_Heatley
  • joined 16 Feb'24 - 1 message
  • United Kingdom
A 51-7 code is flat battery. But if you have just changed the fuel filter on the diesel, check the wiring harness near the filter going to the throttle solenoid as this gets moved each time you do the filter. Unplug the solenoid and clean the plug.
  • Posted 22 Feb 2024 22:42
  • By deepdiver
  • joined 5 May'12 - 6 messages
  • Suffolk, United Kingdom
gray haired old git
Hawker Powersource, Inc.
