Hyster fault code 524225-0, what is it?
Hello everyone, I'm new here. I have 2 Hyster forklifts. It would be nice to have a list of all the fault codes for refrence. However my curent issue is fault code 524225-0. It stops the trucks forward momentem and comes up on the display. Along with "truck disabled". If anyone could help me out it would be greatly appreciated. You can post up here or email me jbenek @ lccg.biz
Thanks,
Joe Benek
  • Posted 14 Jun 2010 20:20
  • By Splashman
  • joined 14 Jun'10 - 1 message
An unknown reader tried to post this message
"If you solve this problem can you know me the reason" please.
Thanks
Admin
  • Posted 28 Oct 2023 23:45
  • By Admin
  • joined 18 May'04 - 266 messages
  • Queensland, Australia
Actuellement j'ai mon chariot qui affiche se même code de défaut 524225-0 au tableau de bord et j'aimerai savoir comment faire pour résoudre le problème.
Merci
  • Posted 5 May 2020 14:49
  • By Demesse_Nangmo
  • joined 5 May'20 - 1 message
  • Cameroon
Demesse
XMSN Forward 1 Pressure Greater Than Commanded Pressure
swap the forward and reverse pressure valve for diagnostic or replace the forward pressur valve
  • Posted 13 Jun 2019 21:54
  • By redbull
  • joined 14 Oct'16 - 108 messages
There is no 0202 fault code. Recheck the code.
  • Posted 10 Jun 2019 22:30
  • By BREWSKI
Hi , everyone I just need your information that my forklift Hyster had an error code 0202 and transmission signal showing on the display and it will work just for seconds and will turns off automatically, do you think the transmission was the issue or sensor ? ,Thank you in advance
  • Posted 10 Jun 2019 03:02
  • By ENG_Nasser_66
  • joined 10 Jun'19 - 1 message
  • Saudi Arabia
I change the pressure sender and I resolve the problem!
Thanks
  • Posted 7 Jun 2016 09:39
  • By Mecanmax
  • joined 7 Jun'16 - 2 messages
  • Quebec, Canada
This is probably a sensor failure. Forward pressure 2 high. The service manual is expensive, but it has all the codes and troubleshooting info. Probably a good investment with two trucks.
  • Posted 1 Oct 2015 22:48
  • By BREWSKI
have you changed the transmission oil and filters? including the one at the bottom plug?
  • Posted 1 Oct 2015 11:42
Just wanted to know if you had an answer on this , I m having the same problem , if you had an answer , please let me know
  • Posted 1 Oct 2015 01:49
  • By robin_j
  • joined 1 Oct'15 - 4 messages
Crown WP302020
UN Forklift FL20-32LNJX2
Crown WP302020
