Hyster code 523925-4
Randomly truck sets code 523925-4. I have the diag test but if it is not setting the code at that time it's pretty much useless. Has anyone ran across an issue like this
  • Posted 13 Jul 2019 02:57
  • By Willietinva
  • joined 13 Jul'19 - 2 messages
  • Virginia, United States
William Salyer
DTC 523920-4 - REV1 Circuit OORL
DTC 523925-4 - Range1/FWD2/REV1 Return Circuit OORL
DTC 523930-4 - Clutch FWD1/Return Circuit OORL
DTC 523977-4 - Aux 2 Base/Rod Coil Driver OORL
DTC 523978-4 - Aux 1 Base/Rod Coil Driver OORL
DTC 523986-4 - Aux 3 Base/Rod Coil Driver OORL
DTC 524284-4 - Lift/Lower/Return Circuit OORL
DTC 524285-4 - Tilt Base Circuit OORL
POSSIBLE CAUSE
A. COIL DRIVER/DRIVER RETURN SHORTED TO GROUND
B. FUNCTIONAL VALVE FAILURE
C. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 13 Jul 2019 07:16
  • By BREWSKI
GemOne
