hyster backup alarm how to fit
hyster
model H3.5 ft
L177B27919G from 2009
who knows how you conect an reverse alarm and where are the plug/??????
  • Posted 19 Feb 2009 02:43
  • By michel_v
  • noord holland, Netherlands
I need update vsm for backup alarm and for redoes speed
  • Posted 22 Feb 2009 21:20
  • By michel_v
tomorrow I will make of it a study
  • Posted 19 Feb 2009 11:08
  • By michel_v
I am always glad to help where I can. NoBody will always strive to give the best information... When you can't count on anyone else you can count on NoBody... HA-HA sorry 'bout the pun.
Glad to Help, let me know how it goes.
  • Posted 19 Feb 2009 11:01
  • By NoBody
  • joined 21 Mar'08 - 11 messages
  • Virginia, United States
tenks for de info nobody
  • Posted 19 Feb 2009 10:55
  • Modified 19 Feb 2009 10:56 by poster
  • By michel_v
This Particular truck, you said it is a 2009 model? that should put it as a Fortis or FT truck, correct.
I believe you should find the connector under the floor board around the break pedal. It should have a four function horn there that also serves as a back up alarm. If this truck shipped with out a back up alarm, you will probably have to turn the function on by accessing the programming either through the dash or the VSM. it may be that the option is only turned off.
These trucks are supposed to have a common wire harness, so I suspect the above to be true. It will be difficult to connect an after market back up alarm, you may have to monitor your reverse pressure via a switch, which you may be able to do be using a pressure test port on the control valve body.
Good luck, and let me know how it turns out.
  • Posted 19 Feb 2009 10:05
  • By NoBody
Toyota 02-8FD30
Terberg RT403
Toyota 02-8FD30
Terberg RT403
