Hyster A216 J 20.-3.20
Code 127 Hyster Gray box liftcontrol (GE) controller
I drive and lifting and tilting etc shift for half hour no problem and than I do shift al hydraulics stop
Only steering works and drive
I do reset with key start up Again everything works perfect 1 hour no problem 2 hours no problem shift all stops end sometime's he work again problem one second.
I go crasy I did measerments on box pin 1 and 2 are 80Volts print for the levers 80 volts out put of print to Box oké wiring is all good
Wiring 51-52-53 all oke I did test outputs to controller they oké 4.7V neutral and make move the lever its up to 9V When all works same measerments
I think box is not good
somebody have any Idééé
Regards
John.
  • Posted 9 Mar 2011 06:14
  • By johngen
  • NB, Netherlands
Check wire 100(temperature sensor) if 0 check Terminal A2. If it is at battery volts when calling for any hydraulic function the GE box is bad; if A2 is less then the battery volts when calling for any hydraulic function, the motor is bad. Make sure you check pin 10 L.I. for correct voltage.
  • Posted 10 Mar 2011 02:38
  • Modified 10 Mar 2011 02:46 by poster
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
mike_retired
problem may be some transistor or diode that stay open when heating or insulation in the engine or another site that you have not yet seen. are some things that betrays us
  • Posted 9 Mar 2011 08:40
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
